pltIPlot GetTipToTailSelectionMethod
Gets the selection method for the tip-to-tail curve.
pltIPlot_ctrl GetTipToTailSelectionMethod
HyperGraph Polar Plot/Tip to Tail functionality.
This command gets the selection method for the tip-to-tail curve. Returns a string indicating the selection method. Options include “none”, “all”, “displayed”, and “selected”.
- None
 - None of the vectors is selected. Manual selection is not allowed.
 - All
 - All vectors are selected. Manual selection is not allowed.
 - Displayed
 - Based only on the displayed vectors, you can select vectors manually.
 - Selected
 - Based on all the vectors of the plot, you make selections.
This command is only valid for polar plots, vector mode.
pltIPlot_ctrl  GetTipToTailSelectionMethod allErrors
Returns an empty string.
