pltIPlot CutVerticalDatum
Cuts a horizontal datum.
pltIPlot_handle CutVerticalDatum datum, append_future
HyperWorks Tcl Modify
This command cuts a vertical datum based on the user-input datum index. A datum is a line used for comparison.
- datum
 - The datum index (position in the datum list) that you want to cut.
 - append_future
- true
 - Indicates the cut is added to a memory.
 - false
 - Indicates that the cut is not added to memory. This way, multiple cuts can be made and pasted at the same time, rather than cutting and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CutVerticalDatum 1 true
Keywords
HyperWorks
Tcl
XY Plot
Datum
Query
