pltIPlot SetTipToTailSelectionMethod
Sets the selection method for the tip-to-tail curve.
pltIPlot_ctrl SetTipToTailSelectionMethod method
HyperGraph Polar Plot/Tip to Tail functionality.
This command sets the selection method for the calculation and drawing of the tip-to-tail curve.
- method
 - Options include
- “none”
 - None of the vectors is selected. Manual selection is not allowed.
 - “all”
 - All vectors are selected. Manual selection is not allowed.
 - “displayed”
 - Based only on the displayed vectors, you can select vectors manually.
 - “selected”
 - Based on all vectors of the plot, you make selections.
pltIPlot_Ctrl SetTipToTailSelectionMethod none
All vectors are included in the calculation and drawing of tip-to-tail curve.
pltIPlot_Ctrl SetTipToTailSelectionMethod all
You can manually select from the list which vectors should be included in the calculation and drawing of tip-to-tail curve.
pltIPlot_Ctrl SetTipToTailSelectionMethod selected Errors
Returns an error code for invalid arguments.
