pltIPlot PasteRadicalDatum
Pastes previously copied or cut radical datum lines.
pltIPlot_handle PasteRadicalDatum index
HyperWorks Tcl Modify
This command pastes previously copied or cut radical datum lines into the datum list. A radical datum is a line that goes from the center outward in the polar plot. It is used for comparisons.
- index
 - The index (position number) where you want to insert datum line. PasteRadicalDatum pastes the user-input index and moves the list down one position if it is at or below that index.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot PasteRadicalDatum 3;
Keywords
HyperWorks
Tcl
Polar Plots
Datums
Modify
