pltIPlot CopyHorizontalAxis
Copies a horizontal axis.
pltIPlot_handle CopyHorizontalAxis axis, append_future
HyperWorks Tcl Modify
This command copies a horizontal axis based on the user-input axis index.
- axis
 - The axis index (position in the axis list) that you want to copy.
 - append_future
- true
 - Indicates the copy will be added to a memory.
 - false
 - Indicates that the copy is not added to memory. This way, multiple copies can be made and pasted at the same time, rather than copying and pasting each one individually.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot CopyHorizontalAxis 1 true;
Keywords
HyperWorks
Tcl
XY Plot
Modify
