Available Boundary Conditions for Analyses
A comparison chart showing the available boundary conditions for each analysis type.
An "X" indicates the boundary condition is available for the analysis type. An empty cell indicates it is not available.
Boundary Condition | Structural | Multi-loadcases | Modal | Dynamics | Frequency Multi-loadcases | Thermal |
Immovable Constraint | X | X | X | |||
Slider Constraint | X | X | X | |||
Hinge Constraint | X | X | X | |||
Spring Support | X | X | X | |||
General Constraint | X | |||||
Alignment | X | |||||
Cable tightening/Rod preload | X | |||||
Pressure | X | X | X | X | ||
Force/Displacement | X | X | X | |||
Forces | X | |||||
Gravity Load | X | |||||
Translational/Rotational Inertia | X | X | ||||
Inertia Relief | X | X | ||||
Remote Load | X | X | X | X | ||
Remote Displacement | X | |||||
Thermal Load | X | |||||
Bearing Load | X | X | X | |||
Hydrostatic Pressure | X | |||||
Distributed Mass | X | X | ||||
Volume Expansion/Shrinkage | X | |||||
Temperature | X | |||||
Surface Heat Flux | X | |||||
Thermal Convection | X | |||||
Volume Heat | X |
Imported Boundary Conditions from CSV
Boundary Condition | Structural | Multi-loadcases | Modal | Dynamics | Frequency Multi-loadcases | Thermal | Fatigue |
Forces | X | X | X | ||||
Spot Forces | X | X | X | ||||
Spot Displacements | X | ||||||
Remote Loads | X | X | X |
