Force/Displacement
Apply uniform loads and/or displacements to faces, edges, vertices, or spots.
Note: Displacement is disabled for multi-loadcases.
- On the Project Tree, open the Analysis Workbench.
In the workbench toolbar, click the
(Force/Displacement) icon.
- Specify which type of entity will have constraints applied.
- Optional: If applying to Faces, you can select the Add tangent faces check box.
- Optional: If applying to Spots, you can create new spots by clicking Create new spot.
- On the modeling window, click to select specific parts on the model.
Specify the coordinate system to which the force/displacement will be
applied.
The default is set to the Global coordinate system, which is automatically created upon geometry import.
- Specify Cartesian or Cylindrical.
- Specify the Force and Displacement units.
Specify Total load or displacement along the X, Y, and Z axes.
- Use the drop-down menu beside each field to select Force or Displacement.
- Enter the desired numerical value into the text box.
In Non-linear Structural Analysis, specify either follower force or fixed
direction force for each axis.
Click the
(Follower load) icon.
The icon will highlight. This designates a follower force. - Leave the icon unhighlighted to designate fixed direction force.
Click the
- Click OK.
