Load Field Data From CST Near Field Scan (NFS)
| AP Card | I1 I/S |
I2 I/S |
I3 I/S |
I4 I/S |
I5 I/S |
R1 REAL |
R2 REAL |
R3 REAL |
R4 REAL |
R5 REAL |
R6 REAL |
R7 REAL |
R8 REAL |
| Line 1 | |||||||||||||
| Line 2 |
Parameters (INTERNAL):
- I1
- PRE & FEK File
- 0
- New excitation, replaces all previous excitations.
- 1
- Additional excitation, add to previous excitations.
- I2
- PRE File
- 31
- CST near field scan directory (contains multiple files).
- FEK File
- The type maps to ±9 that correspond to both electric and magnetic field values for a planar aperture that follow in the .pre input file.
- I3
- PRE File
- Reference point (refers to a named point).
- FEK File
- Use the aperture definition from the file using the nth data block as specified by this number.
- I4
- PRE File
- Direction of the U-vector (refers to a named point).
- FEK File
- The number of field points in the S1–S2 direction.
- I5
- PRE File
- Direction of the V-vector (refers to a named point).
- FEK File
- The number of field points in the S1–S3 direction.
- R1
- PRE File
- FEK File
- Scale the amplitude of the field values.
- R2
- PRE File
- Describes where the reference point from I3 is
located relative to the aperture box.
- 1
- Base corner
- 2
- Box centre
- 3
- Face centre (U-min)
- 4
- Face centre (U-max)
- 5
- Face centre (V-min)
- 6
- Face centre (V-max)
- 7
- Face centre (N-min)
- 8
- Face centre (N-max)
- FEK File
- Constant additional phase for the field strength (in degrees).
- R3
- FEK File
- AP_S1_x (The x-value of S1).
- R4
- PRE File
- FEK File
- AP_S1_y (The y-value of S1).
- R5
- PRE File
- FEK File
- AP_S1_z (The z-value of S1).
- R6
- PRE File
- Super user option
- 0
- Activate all default optimisations.
- 1
- Do not use a spherical source representation for this AP card.
- Swap source and field validity regions (since fek format 173)
- 2
- Bitset option. This option is used for spherical, cylindrical or Cartesian boundary options to swap the source and field validity region. This option is not available for single Cartesian faces. By default, an aperture represents a source that is inside the aperture. The fields inside the box/sphere/cylinder are zero and the fields outside the box/sphere/cylinder are equivalent to the calculated or measured field values. When this option is selected, the aperture represents a source that is outside the aperture. The field contribution outside the box/sphere/cylinder is zero and the fields inside the box/sphere/cylinder are equivalent to the calculated or measured field values.
- FEK File
- AP_S2_x (The x-value of S2).
- R7
- FEK File
- AP_S2_y (The y-value of S2).
- R8
- FEK File
- AP_S2_z (The z-value of S2).
- Filename
- Path to the directory containing the CST near field scan files.
- Label of request.
- I'5
- Super user option
- 0
- 1
- 2
- Bitset option. The aperture represents a source that is outside the aperture.
- R'1
- AP_S3_x (The x-value of S3).
- R'2
- AP_S3_y (The y-value of S3).
- R'3
- AP_S3_z (The z-value of S3).
