udfHasTurb()
Does this problem contain a turbulence equation?
turbFlag = udfHasTurb( udfHd ) ;
AcuSolve User-Defined Function Global
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- turbFlag (integer)
- Flag indicating whether or not this problem has turbulence equation(s). The return value is a flag indicating whether or not this problem has turbulence equations:
- 0
- No
- 1
- Yes
Integer turbFlag ;
if ( turbFlag == 1 ) {
/* Logic if turbulence equations exist */
)Errors
This routine expects a valid udfHd.
