Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using
best-in-class solver technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Below are the steps for Manual E-Line Creation method, in
which you will be creating connector locations by selecting single or multiple
master and slave components and providing various parameters. Select
Manual radio button in Method, and
the panel will be displayed as below Manual E-line Method: t
You can do the following operations in the panel -
Master Component(s) - to select the master component
Slave Component(s) - to select the respective slave component for
interface creation
Geometric Lines - to select the geometric line for the selected
components
Spacing and Search Distance- numerical value to define the
spacing between the connector placements
Interface Name - to select and define a name for the interface
E-Line Type - drop down list to select the required line type. Line
types are -
Rattle
Squeak
Gap Direction - to define the gap direction with respect to master
component. SnRD supports two directions, namely:
Normal to Master - where the gap direction is perpendicular
to master component
In-plane to Master - where the gap direction is in plane, or
is not perpendicular to master component
Define the Contact Types based
on the Youngs' Modulus.
Create - after making the necessary selections, you can click
Create. This will create the connector locations
in the model
Undo - you can revok or undo the connectors created in the immediate
previous step
