SnRD Post - Results Processing
This section of the document guides you through the process of post-processing. Using the following steps, you will be able to load the model and its corresponding result files and generate the plots required for the analysis and evaluation of the simulation results.
For SnRD Post processing, the following file formats are required. These files are generated when you solve a solver deck on OptiStruct:
  • .PCH - PUNCH file containing the displacement data for the node set defined in Output Request Creation
  • .H3D - HyperWorks X results file containing the modal displacement data.
The following sections in this chapter will take you through the steps of loading and post processing the results to evaluate squeak and rattle issues.
