Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using
best-in-class solver technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Sensitivity Analysis is the next step in the post processing of
SnRD Post. The standard post-processing in SnRD offers the
functionality to generate time domain displacement plots of each of the node-pairs of
all the E-lines that are present in the model. The purpose of the Sensitivity
Analysis is to study the root cause of rattle and/or squeak at each
E-Line. Two main diagnosis functionalities are enabled in SnRD sensitivity analysis step
and are listed below -
Determination of Relative Modal Contribution to squeak
and rattle of complete E-Lines and as well as at specific points on each
E-Line
Capability to check the effect of changing the percentage of modal contribution
on the squeak and rattle performance
Sensitivity Analsysis tab is as shown below.
Below are the operations which can perform in Sensitivity Analysis
tab -
Result File - drop down list to select the results file
loaded in the SnRD Main Tab
Subcase Name - drop down list to select the subcase
associated with the selected Result File
Modal Result File (h3d) - to select a
H3D file containing the modal contribution results.
Calculation Type -
The sensitivity analysis is a two
step process.
The first step is to calculate the Relative Modal
Contribution of the required E-Line to be
analyzed.
The second step is to observe the change in results when the modal
contribution is varied but either including a certain mode or
excluding it from result calculations with the help of
Modal Sensitivity study. The relative
modal contribution for a particular E-Line can be calculated and
studied in two ways:
Study the modal contribution of the complete E-Line
Study the modal contribution of a particular node pair of an
E-Line
The post-processing done on SnRD results provides the information about
the E-Lines that are exhibiting undesired squeak and rattle behavior. In the
sensitivity analysis the problematic E-Lines can be chosen for study. The
Post-processing results also provide the information about which node-pair
of an E-Line show the highest undesirable results.
