Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using
best-in-class solver technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Load Creation is the first step in process flow. You can
create or define loads by importing a load definition CSV file. Below is the
Load panel.
You can do the following operations in the panel:
Load File - select a load definition file. SnRD supports the following file
formats:
CSV
TXT
Add - this will import the load data and create a Tabled1
data in the table
Update - you can update a tabled1 data with a new load definition file
Entry Selection Options - to perform selection options, like Select All,
Unselected All and Reverse Selection for the table entry items
Refresh Data - to refresh the data in the panel
Delete options - to delete all or delete selected items in the panel
HyperGraph plot - you can visualize the Tabled1 data in a HyperGraph chart
for a load from the table.
