Rename a Rake
  1. From the Streamlines panel, right-click the name of a rake in the Rakes list and select Rename from the context menu.
  2. Type a new name into the Rename dialog.
  3. Click OK.
    Or
    1. From the Model Browser, right-click the name of the rake in the tree (listed under the Streamlines folder) and select Rename from the context menu.
  4. Enter a new name in the name text field and press Enter. The rake is renamed.
