Tags
Tag entities tag a piece of information, called the body, onto a node, element, line, surface, point, or solid within the model.
Limitations
Tags are automatically deleted when:
  • A tag is on a surface edge and the edge is split, toggled (in either direction), or surface normals are adjusted.
  • A tag is on a free line and the free line is split.
  • A tag is on a surface vertex and all but one (owning parent of the vertex) of the associated surfaces are deleted, or the vertex is toggled (in either direction).
