abstat_mat
Option Description Supports
ABSTAT Airbag statistics.
Reads airbag and blocked materials statistics from LS-DYNA files into HyperGraph 2D.
The data read in is sorted by time steps specified in the input file.
Volume, pressure, internal energy, input mass flow rate, output mass flow rate, mass, temperature, and density.
Airbag material leakage (from LS-DYNA R11.1).
