Supported Abaqus ODB History Results
The Abaqus ODB reader in HyperView and HyperGraph 2D reads both field and history results from the Abaqus ODB file.
The history result names are post fixed with (Time History). Results without this post fix are field data. Time history results have two components (or columns): Time and Value.
Time
The Time component is the first column of the result. The value can be time steps, frequency, or mode number, depending on the analysis types.
Value
The Value component is the actual value for the result type.
Note: Time data for different result types can be different. It is recommended to use both the Time and Value from the same result type.
