hgradioss
Description Supports Does Not Support
Reads Radioss T01 files (result files generated by the solver) into HyperGraph 2D. Global Variables
PARTS
PROP
MAT
NODE
BRIC
QUAD
SHEL, SH3N
BEAM
TRUSS
SPRING
ACCEL
SECTIO
CYL_JO
MONV
RWALL
RBODY
INTER
SUBS
NSTRAND
Usage
To run from the command prompt:
  • hgradioss(.exe) –f fileT01 outfile
To run in HyperGraph 2D:
  • By default, this reader is registered. If not, please register it before reading T01 files directly into HyperGraph 2D. It is located in the HWDIR\externalreaders\ directory.
