hgopt_ansys
An ANSYS translator that reads .rst ANSYS files that have structural or couple field analysis into HyperGraph 2D and HyperStudy.
Supports
The .rst files are converted into .bin files that can be read by HyperStudy.
The response type is the load step.
The requests are element or nodal data.
For element data, the components are the element result vs. the element number.
For nodal data, the components are the nodal result vs. the node number.
