Edit a Legend
  1. From the HyperGraph 3D Curve Attributes panel, click Surface tab > Edit legend....
  2. Select the attributes that you want to apply to the legend.
    The changes are previewed on the sample legend, located on the right side of the dialog.
  3. Click Apply.
  4. Click Default to restore the default values for the legend.
  5. Click OK to exit or Cancel to disregard the changes made.
