View Waterfall Plots from a Top View
  1. From the HyperGraph 3D Curve Attributes panel, click Top on the view controls, located in the lower right corner of the application.
  2. Select the Surface tab.
  3. Activate the Contour check box.
  4. Under Expression:, set the contour expression to Z to see the Z values represented as the contour.
