Select a Range of Curves
  1. From the HyperGraph 3D Curve Attributes panel, select a curve from the Curves list.
  2. Drag the pointer to include the curves above or below the selected curve.
Or
  1. Select a curve from the list.
  2. Hold down the Shift key and select another curve from the Curves list.
    The range of curve names between the first and second selections is highlighted.
