Cut, Copy, and Paste Curves
  1. Select a curve from the list or pick a curve from the window.
  2. Click Copy from the curve list controls.
    The selected curve is copied to the clipboard, leaving the original behind. The copied curve can be pasted in any window.
  3. Click Cut from the curve list controls.
    The selected curve is removed from the list and is no longer displayed in the active window.
  4. After cutting or copying a curve, select a new plot window.
  5. Click Paste from the Curve list controls.
    The curve is added to the active window’s curve list and is displayed in the active window.
