Layout Options
Use the Layout menu to specify how the plotted data is arranged on the page.
Field
Use Current Plot
Every curve is overlaid in the active window.
When one of the following options is selected, the page layout icon becomes available.
One Plot Per Request
Each selected request is plotted in a new plot with the corresponding components overlaid.
For example, if two Y requests and four Y components are selected, two plots are created with four curves in each plot.
One Plot Per Component
Each selected component is plotted in a new plot with the corresponding requests overlaid.
For example, if two Y requests and four Y components are selected, four plots are created with two curves in each plot.
One Curve Per Plot
Each curve is plotted in a new plot.
For all plotting options, a new page is created. The layout of the new page can be selected from the page layout button on Build Plots. When the plots are built, each window on the new page is filled. If more windows are required, another page of the same layout is created.
Apply
Click Apply to construct all the curves at once.
The program automatically generates axis labels, plot titles, and page names. They can be edited using the Axes and Title panels and the Page List dialog.
Plots can contain up to six horizontal and six vertical axes. All curves created using Build Plots are automatically assigned to the primary horizontal and vertical axes.
