Apply an Existing Plot Macro
  1. From the Plot Macros panel, select a macro from the list.
  2. Type in scalar parameter values or select curves using the collectors.
  3. Select a curve by pressing Shift and picking a curve from the screen or select a curve from the tree.
  4. Select a method for placing the new curves from the Layout section.
  5. Click Apply.
  6. Click Undo to remove the macro.
