Edit an Existing Plot Macro
  1. From the Plot Macros panel, select a macro from the list.
  2. Click Edit.
    The Edit Plot Macro dialog is displayed.
  3. Click the Parameters tab.
  4. Add parameter names or edit existing names in the Parameters text box.
  5. Select parameter types from the Type combo box.
  6. Add or edit parameter variable names in the Varname text box.
  7. Click the Curve tab.
  8. Select a parameter.
  9. Edit the X and Y coordinates.
  10. Click Close.
  11. Edit the macro name in the Macro text box.
  12. If desired, rename the macro by highlighting the name from the list, entering a new name in the Macro field, and pressing Enter.
