Query
Use the Query tool to view and export properties and other information for nodes, elements, components, and systems contained in the active model.
From the Results toolbar, click Query .
Note: You can also select Query from the Results menu.
Figure 1. Query Panel
The input collector and the option list allow you to define the selection set to be queried.
