Tensor
Use the Tensor tool to view tensor plots of stress and strain directions and magnitudes for various solvers from elemental values.
From the Results toolbar, click Tensor Plots .
Note: You can also select Plot > Tensor from the Results menu.
Figure 1. Tensor Panel
Attention: The Envelope utility is not intended for use with tensor plots. If it is used with a tensor plot, HyperView will simply draw the last loadstep in the derived loadstep list.
