Create Plot Style
  1. Open the Tensor panel in the following ways:
    • From the Results toolbar, click Tensor .
    • Select Plot > Tensor from the Results menu.
  2. From the Tensor panel, click the Create Plot Style button.
    Opens the Create/Update Tensor Plot Style dialog, which allows you to create or update a result plot style based on the current settings of the tensor.
    Note: A tensor plot needs to be current in order to create a new style or modify an existing one.
    All the settings of the tensor plot (resolved in systems, default data type/components, display options, legend, etc.) are captured in the named style.
