Query Results
  1. Open the Vector panel in the following ways:
    • From the Results toolbar, click Vector .
    • Select Plot > Vector from the Results menu.
  2. From the Vector panel, click the Query Results button.
    Opens the Query panel where you can view and export properties and other information related to nodes, elements, components, and systems contained in the active model.
    Note: Only the individual components will be returned by the query (no shear results).
