hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Projects a node to a plane along a vector.
Creates a vector from two points.
Calculates the angle between two vectors.
Calculates the cross product of two vectors.
Calculates the dot product of two vectors.
Calculates a vector defined by three points.
Calculates the magnitude of a vector.
Calculates the normalized cross product of two vectors.
Calculates the normalized dot product of two vectors.
ON THIS PAGE
ON THIS PAGE
