HM_strxint()
Extracts the integer value from a string.
int HM_strxint(char * string);
HyperMesh hmlib Function
string
A pointer to a string.
The integer value found in the string.
This function looks for the first occurrences of the characters "0" through "9" and then converts that character along with all other valid integer characters which follow it.
None.
