HM_strrep()
Replaces a string within a string.
char * HM_strrep(char * string, char * replace, char * with);
HyperMesh hmlib Function
string
A pointer to a string that is to have a substring replaced with another string.
replace
A pointer to a string that contains the string to be replaced.
with
A pointer to a string that contains the string that is to replace any occurrences of *replace.
A pointer to *string.
None.
