HM_strdel()
Deletes a string of characters from a string.
char * HM_strdel(char * string, int position, int length);
HyperMesh hmlib Function
string
A pointer to a string that is to have characters deleted.
position
The position in the string where deletion should start.
length
The number of characters that should be deleted.
A pointer to the string.
None.
