HM_Face
Contains information about an individual face in the topology of mesh areas defined by the HM_Topology structure.
struct HM_Face {
int size;
int error_status;
HM_EntityTopology mapped_hm_topo;
int num_loops;
int num_points;
int* loops;
int* points;
double mesh_size;
int component;
int local_batchparamset_num;
HyperMesh Ext API Function
This structure contains information about an individual face in the topology of mesh areas defined by the HM_Topology structure.
The structure information is declared in hm_extapi.h.
The members are: size, error_status, num_loops, num_points, loops, points, mesh_size, component, and local_batchparamset_num
size
Specifies the length, in bytes, of the structure. Use sizeof(HM_Face) for this member. This is used to distinguish the current version of HM_Face from possible future extended versions with additional members.
error_status
Used by API functions to return an error status. A value of zero indicates successful completion of a function using this structure.
mapped_hm_topo
Some API functions will use this member to return a handle to an edge entity corresponding to the edge specified by the HM_Face structure. On input, set to zero. The function HM_ExtAPI::GenerateMesh() does not use this member to return any values.
num_loops
The total number of face loops defining the face specified by this HM_Face structure.
num_points
The total number of internal fixed points, not connected to any edges, within the face specified by this HM_Face structure.
loops
Pointer to an array of face loop references. The number of values in the array must not be smaller than the value specified by the num_loops member of this HM_Face structure.
Each number in the array pointed to by loops represents a zero-based index in the array of the HM_FaceLoop structures pointed to by the loops member of the HM_Topology structure that contains this HM_Face structure in its faces array.
points
Pointer to an array of internal fixed point references. The number of values in the array must not be smaller than the value specified by the num_points member of this HM_Face structure. If num_points is zero then the points member is not used and should be set to NULL.
Each number in the array pointed to by points represents a zero-based index in the array of HM_Vertex structures pointed to by the vertices member of the HM_Topology structure that contains this HM_Face structure in its faces array.
mesh_size (optional)
Set individual mesh size for the face specified by this HM_Face structure. Set to positive value in order for individual mesh size to be used for this face. Set to -1 to have the mesh size the same as the value specified by global mesh size parameter.
component
A reference to the HM_Component structure of the component comprising the face.
It represents a zero-based index of the component structure in the components array of the HM_Topology structure that contains this HM_Face structure.
local_batchparamset_num (optional)
Reference to an individual batch mesh parameter/criteria file set for meshing of the face in the batch mesh mode. Assign it as a positive number to specify a local batch mesh parameter set using the number of the set in the HM_GenerateMeshParamStruct local_batchparamsets array (zero-based index of the set in the array local_batchparamsets incremented by 1). Assign it as 0 to specify explicit batch meshing of the face with the global parameter and criteria files from HM_GenerateMeshParamStruct. Assign it as -1 to use the batch mesh parameter and criteria set specified for the topology component HM_Component comprising the face.
None.
