HM_PolyLine
Contains information about the geometry of a line represented by approximation points.
struct HM_PolyLine {
int num_points;
HM_Point* points;
HyperMesh Ext API Function
This structure contains information about the geometry of a line represented by approximation points.
The structure information is declared in hm_extapi.h.
The members are: num_points and points
num_points
The number of points in the line approximation.
points
Pointer to an array of HM_Point structures representing individual points. The number of entries in the array must not be smaller than the value specified by the num_points member of this HM_PolyLine structure.
None.
