HM_ImportModelParamStruct
Contains information that is used by the HM_ExtAPI::ImportModel() function to set import parameters.
struct HM_ImportModelParamStruct {
int size;
double import_tol;
double scale_factor;
bool import_blanked;
bool comps_by_layer;
bool get_assm_tree_only;
bool get_abs_matrices;
bool use_default_reader;
HyperMesh Ext API Function
This structure contains information that is used by the HM_ExtAPI::ImportModel() function to set import parameters.
In the function HM_ExtAPI::ImportModel() the pointer to HM_ImportModelParamStruct can be set to NULL. In this case default values of the import parameters are used as specified below.
The structure information is declared in hm_extapi.h.
The members are: size, import_tol, scale_factor, import_blanked, comps_by_layer, get_assm_tree_onlyget_abs_matrices, use_default_reader
size
Specifies the length, in bytes, of the structure. Use sizeof(HM_ImportModelParamStruct) for this member. This is used to distinguish the current version of HM_ImportModelParamStruct from possible future extended versions with additional members.
import_tol
Specifies model import tolerance. If the value of this parameter is less that zero then import tolerance is set automatically by HyperMesh (default behavior).
scale_factor
Specifies additional scaling of imported model. If the value of this parameter is less than zero then no scaling is applied (default behavior).
import_blanked
The flag that specifies whether components blanked in original CAD model are imported. This member can have one of the following values:
false - Blanked components are not imported (default behavior).
true - Blanked components are imported.
comps_by_layer
The flag that specifies whether separate components are created for each layer of imported CAD model. This member can have one of the following values:
false - No separate components are created for layers (default behavior).
true - Separate components are created for different layers.
get_assm_tree_only
The flag that specifies whether to import or only create the assembly structure. This member can have one of the following values:
false - Normal import (default behavior).
true - Only the assembly structure and transformation matrices will be provided.
get_abs_matrices
Defines how the transformation matrices are saved when get_assm_tree_only is true. This member can have one of the following values:
false - Relative transformation matrices are saved (default behavior).
true - Absolute transformation matrices are saved.
use_default_reader
The flag that specifies whether to use the default CAD reader or the "other" CAD reader for supported formats. This member can have one of the following values:
false - Use the other reader.
true - Use the default reader (default behavior).
None.
