HMMOD_nodesetdisplacement()
Assigns displacement values to a node specified by the node pointer.
void HMMOD_nodesetdisplacement(void * nodeptr, float x, float y, float z);
HyperMesh hmmodlib Function
nodeptr
The pointer to the node.
x
The displacement value to be assigned to the x coordinate.
y
The displacement value to be assigned to the y coordinate.
z
The displacement value to be assigned to the z coordinate.
None.
