(unary)-
Additive inverse.
-expr
Operand
expr
A valid scalar, vector, or matrix expression.
Expression Result
-{3} -3
{-{1, 2, 3}} -1, -2, -3
{-{ {1, 2}, {-5, 3}}} {-1, -2}, {5, -3}
The unary operator generates the additive inverse (opposite in sign and equal in magnitude) of expr.
If expr is a scalar, the result is a scalar.
If expr is a vector or matrix, the result is a vector or matrix containing the additive inverses of each element in expr.
