Increment operator.
var_name ++
Operands
var_name
A scalar variable.
Expression Result
a ++ , where a = 2 3
The increment operator increases the value of var_name by one. This operator is typically used in loop constructs.
The increment operator is not valid when used with curve-editing functions.
