Division assignment operator.
var_name /= sca_expr
Operands
var_name
A scalar variable.
sca_expr
A valid scalar expression.
Expression Result
a /= 2 , where a = 2 1
a /= 0.5 , where a = 2 4
The division assignment operator divides the value of var_name by sca_expr. The value of sca_expr must be nonzero. This operator is typically used in loop constructs.
The division assignment operator is not valid when used with curve-editing functions.
