レポートパラメータ
HyperViewでは多くのレポートパラメータがサポートされています。
- Global (Model)
- Model Title (Hvmodel Title)
- Loadcase ID (Hvmodel Loadcaseid)
- Simulation index (Hvmodel Simulationindex)
- MeshMode (Hvmodel Meshmode)
- PolygonMode (Hvmodel Polygonmode)
- Contour
- Data type (Hvcontourctrl Datatype)
- Data comp (Hvcontourctrl Datacomp)
- Legend position (Hvcontourctrl Legendposition)
- Legend header text (Hvlegendheader Text)
- Legend header font name (Hvlegendheader Fontname)
- Legend header font size (Hvlegendheader Fontsize)
- Legend footer text (Hvlegendfooter Text)
- Legend footer font name (Hvlegendfooter Fontname)
- Legend footer font size (Hvlegendfooter Fontsize)
- Tensor
- Vector
- Deformed
- Deformed scale mode (Hvscalectrl Scalemode)
- Deformed scale factor (Hvscalectrl Scalefactor)
- Deformed data type (Hvscalectrl Datatype)
- Undeformed mode (Hvscalectrl Undeformedmode)
- Undeformed color (Hvscalectrl Undeformedcolor)
- Tracing
- Tracing mode (Hvtracingctrl Tracingmode)
- Tracing steps (Hvtracingctrl Tracingsteps)
- Tracing line width (Hvtracingctrl Linewidth)
- Tracing line color (Hvtracingctrl Linecolor)
- Section Cut
- Section cut base coords-x (Hvsection Basecorrdsx)
- Section cut base coords-y (Hvsection Basecorrdsy)
- Section cut base coords-z (Hvsection Basecorrdsz)
- Section cut color (Hvsection Color)
- Section cut cross-section width (Hvsection Crosssectionwidth)
- Section cut label (Hvsection Label)
- Section cut visibility (Hvsection Visibility)
- Measure
- Measure color (Hvmeasure Color)
- Measure font name (Hvmeasure Fontname)
- Measure font size (Hvmeasure Fontsize)
- Measure font slant (Hvmeasure Fontslant)
- Measure font weight (Hvmeasure Fontweight)
- Measure label (Hvmeasure Label)
- Measure visibility (Hvmeasure Visibility)
- Measure entities (Node/Element/Part/System)
- Measure locator1 (Hvmeasurelocator1 Locator1)
- Measure locator2 (Hvmeasurelocator1 Locator2)
- Measure locator3 (Hvmeasurelocator1 Locator3)
注: リストされるロケーターの数は、選択されているメジャータイプによって異なります(例えば、"Position"の場合はロケーター1つのみ、"Distance Between"の場合は2つ)。 - Notes
- Note transparency (Hvnote Transparency)
- Note x coordinates (Hvnote Xcoordinates)
- Note y coordinates (Hvnote Ycoordinates)
- Note z coordinate (Hvnote Zcoordinates)
- Note x position (Hvnote Xposition)
- Note y position (Hvnote Yposition)
- Note border width (Hvnote Borderwidth)
- Note horizontal alignment (Hvnote Horizontalalignment)
- Note anchor to screen (Hvnote Anchortoscreen)
- Note auto hide (Hvnote Autohide)
- Note text (Hvnote Text)
- Note color (Hvnote Color)
- Note fill color (Hvnote Fillcolor)
- Note label (Hvnote Label)
- Note visibility (Hvnote Visibility)
- Note locator (Hvnote Locator)
- Note font name (Hvnote Fontname)
- Note font size (Hvnote Fontsize)
- Note font slant (Hvnote Fontslant)
- Note font weight (Hvnote Fontweight)
- Note entities (Node/Element/Part/System)
- View - CurrentView
- Fit (Hvview Fit)
- Standard View (Hvview Standardview)
- Tracking
- Tracking entity (Hvtrackingctrl Entity)
- Tracking label (Hvtrackingctrl Label)
- Tracking entities (Node/Element/Part/System)
- Tracking locator1 (Hvtrackingctrllocator1 Locator1)
- Tracking locator2 (Hvtrackingctrllocator1 Locator2)
- Tracking locator3 (Hvtrackingctrllocator1 Locator3)
注: リストされるロケーターの数は、選択されているトラッキングタイプによって異なります(例えば、"Node"の場合はロケーター1つのみ、"Plane"の場合は3つ)。
