HyperViewとADVCとのインターフェース
サポートされる結果
データ名 結果タイプ Data Type
Temperature NODE SCALAR
Strain Energy Density NODE SCALAR
Equivalent Stress NODE SCALAR
Hydrostatic Stress (equivalent pressure stress) NODE SCALAR
Volumetric strain NODE SCALAR
Principal Stresses (Maximum, Middle and Minimum) NODE SCALAR
Principal Strains (Maximum, Middle and Minimum) NODE SCALAR
Principal elastic strains (Maximum, Middle and Minimum) NODE SCALAR
Equivalent Elastic Strain NODE SCALAR
Volumetric Elastic strain NODE SCALAR
Volumetric thermal strain NODE SCALAR
Principal thermal strains (Maximum, Middle and Minimum) NODE SCALAR
Equivalent plastic strain NODE SCALAR
Yield stress NODE SCALAR
Volumetric plastic strain NODE SCALAR
Plastic strain magnitude NODE SCALAR
Principal plastic strains (Maximum, Middle and Minimum) NODE SCALAR
Average, Amplitude, Maximum of strain energy density NODE SCALAR
Equivalent creep strain NODE SCALAR
Principal creep strains (Maximum, Middle and Minimum) NODE SCALAR
Displacement NODE VECTOR
Rotation NODE VECTOR
Reaction force NODE VECTOR
Velocity NODE VECTOR
Angular Velocity NODE VECTOR
Acceleration NODE VECTOR
Angular acceleration NODE VECTOR
Eigen vectors of Principal stresses NODE VECTOR
Eigen vectors of Principal strains NODE VECTOR
Eigen vectors of principal elastic strains NODE VECTOR
Eigen vectors of principal thermal strains NODE VECTOR
Eigen vectors of principal plastic strains NODE VECTOR
Eigen vectors of principal creep strains NODE VECTOR
Heat flux vector NODE VECTOR
Temperature gradient vector NODE VECTOR
Negative temperature gradient vector NODE VECTOR
Contact Normal vector NODE VECTOR
Contact displacement NODE VECTOR
Contact Traction NODE VECTOR
Stress tensor NODE TENSOR
Strain tensor NODE TENSOR
Elastic Strain Tensor NODE TENSOR
Thermal strain tensor NODE TENSOR
Plastic strain tensor NODE TENSOR
Creep strain tensor NODE TENSOR
Strain Energy Density ELEMENT SCALAR
Equivalent Stress ELEMENT SCALAR
Hydrostatic Stress ELEMENT SCALAR
Volumetric Strain ELEMENT SCALAR
Principal Stresses (Maximum, Middle and Minimum) ELEMENT SCALAR
Principal Strains (Maximum, Middle and Minimum) ELEMENT SCALAR
Equivalent Elastic Strain ELEMENT SCALAR
Volumetric Elastic Strain ELEMENT SCALAR
Principal elastic strains (Maximum, Middle and Minimum) ELEMENT SCALAR
Volumetric thermal strain ELEMENT SCALAR
Principal thermal strains (Maximum, Middle and Minimum) ELEMENT SCALAR
Equivalent plastic strain ELEMENT SCALAR
Yield stress ELEMENT SCALAR
Volumetric plastic strain ELEMENT SCALAR
Plastic strain magnitude ELEMENT SCALAR
Principal plastic strains (Maximum, Middle and Minimum) ELEMENT SCALAR
Average, Amplitude, Maximum of strain energy density ELEMENT SCALAR
Equivalent creep strain ELEMENT SCALAR
Principal creep strains (Maximum, Middle and Minimum) ELEMENT SCALAR
Yield region ELEMENT SCALAR
Eigen vectors of Principal stresses ELEMENT VECTOR
Eigen vectors of Principal strains ELEMENT VECTOR
Eigen vectors of principal elastic strains ELEMENT VECTOR
Eigen vectors of principal thermal strains ELEMENT VECTOR
Eigen vectors of principal plastic strains ELEMENT VECTOR
Eigen vectors of principal creep strains ELEMENT VECTOR
Heat flux vector ELEMENT VECTOR
Temperature gradient vector ELEMENT VECTOR
Negative temperature gradient vector ELEMENT VECTOR
Stress tensor ELEMENT TENSOR
Strain tensor ELEMENT TENSOR
Elastic Strain Tensor ELEMENT TENSOR
Thermal strain tensor ELEMENT TENSOR
Plastic strain tensor ELEMENT TENSOR
Creep strain tensor ELEMENT TENSOR
