FVSA Lateral and Vertical Location
Request Number: 80000170
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel FVSA Lateral Location | mm | The lateral distance between the left wheel center and the left wheel center
                  front view instant center or: length * cos(angle) See left wheel front view swing arm length and angle calculations in BranchID 160, components 1 and 4 (in Front View Swing Arm Length and Angle).  |
| F3 | RESULT(3) | Right Wheel FVSA Lateral Location | mm |
                   The lateral distance between the right wheel center and the right wheel center front view instant center or: length * cos(angle) See right wheel front view swing arm length and angle calculations in BranchID 160, components 2 and 5 (in Front View Swing Arm Length and Angle).  |
| F4 | RESULT(4) | Average FVSA Lateral Location | mm | The mean of the left and right wheel front view swing arm lateral location. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Wheel FVSA Vertical Location | mm |
                   The vertical distance between the left wheel center and the left wheel center front view instant center or: length * sin(angle) See left wheel front view swing arm length and angle calculations in BranchID 160, F2/RESULT(2) and F5/RESULT(5) (in Front View Swing Arm Length and Angle).  |
| F7 | RESULT(7) | Right Wheel FVSA Vertical Location | mm |
                   The vertical distance between the right wheel center and the right wheel center front view instant center or: length * sin(angle) See right wheel front view swing arm length and angle calculations in BranchID 160, F3/RESULT(3) and F6/RESULT(6) (in Front View Swing Arm Length and Angle).  |
| F8 | RESULT(8) | Average FVSA Vertical Location | mm | The mean of the left and right wheel front view swing arm vertical location. |
