Lateral Force Steer
Request Number: 80000080
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Parallel Lateral Force Steer | deg/kN | The left wheel steer due to parallel lateral forces on the left and right
                  tire patches or:
| F3 | RESULT(3) | Right Parallel Lateral Force Steer | deg/kN | The right wheel steer due to parallel lateral forces on the left and right
                  tire patches or:
| F4 | RESULT(4) | Average Parallel Lateral Force Steer | deg/kN | The mean of the left and right parallel lateral force steer. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Converging Lateral Force Steer | deg/kN | The left wheel steer due to converging lateral forces on the left and right
                  tire patches or:
| F7 | RESULT(7) | Right Converging Lateral Force Steer | deg/kN | The right wheel center steer due to converging lateral forces on the left and
                  right tire patches or:
| F8 | RESULT(8) | Average converging Lateral Force Steer | deg/kN | The mean of the left and right converging lateral force steer. |
