Wheel Center Translational Stiffnesses
Request Number: 80000050
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel Center X Stiffness | N/mm | The left wheel center longitudinal stiffness
                      or: 1/C(1,1)  |
| F3 | RESULT(3) | Left Wheel Center Y Stiffness | N/mm | The left wheel center lateral stiffness
                      or: 1/C(2,2)  |
| F4 | RESULT(4) | Left Wheel Center Z Stiffness | N/mm | The left wheel center vertical stiffness
                      or: 1/C(3,3)  |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Right Wheel Center X Stiffness | N/mm | The right wheel center longitudinal stiffness
                      or: 1/C(7,7)  |
| F7 | RESULT(7) | Right Wheel Center Y Stiffness | N/mm | The right wheel center lateral stiffness
                      or: 1/C(8,8)  |
| F8 | RESULT(8) | Right Wheel Center Z Stiffness | N/mm | The right wheel center vertical stiffness
                      or: 1/C(9,9)  |
