Ride Steer, Caster, and Camber
Request Number: 80000180
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel Ride Steer | deg/m | The left wheel steer angle change due to in-phase vertical deflections of the
                  left and right wheels
                      or: rtod*(C(6,3)+C(6,9))/(C(3,3)+C(3,9))*1000  |
| F3 | RESULT(3) | Left Ride Caster | deg/m | The left caster angle change due to in-phase vertical deflections of the left
                  and right wheels or:
| F4 | RESULT(4) | Left Wheel Ride Camber | deg/m |
                   The left wheel camber angle change due to in-phase vertical deflections of the
                    left and right wheels or:
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Right Wheel Ride Steer | deg/m | The right wheel steer angle change due to in-phase vertical deflections of
                  the left and right wheels
                      or: rtod*(C(12,3)+C(12,9))/(C(9,3)+C(9,9))*1000  |
| F7 | RESULT(7) | Right Ride Caster | deg/m | The right caster angle change due to in-phase vertical deflections of the
| F8 | RESULT(8) | Right Wheel Ride Camber | deg/m | The right wheel camber angle change due to in-phase vertical deflections of
                  the left and right wheels or:
