Wheel Rate, Ride Rate, and Hop Rate
Request Number: 80000210
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Wheel Rate | N/mm | The left wheel vertical stiffness (excluding tires) when both the left and
                  right wheels are moving in-phase
                      or: 1/(C(3,3)+C(3,9))  |
| F3 | RESULT(3) | Left Ride Rate | N/mm | The left wheel vertical stiffness (tires in series) when both the left and
                  right wheels are moving in-phase or: ((wheel rate)*(tire stiffness))/((wheel rate)+(tire stiffness))  |
| F4 | RESULT(4) | Left Hop Rate | N/mm | The left wheel vertical stiffness (tires in parallel) when both the left and
                  right wheels are moving in-phase or: (wheel rate) + (tire stiffness)  |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Right Wheel Rate | N/mm | The right wheel vertical stiffness (excluding tires) when both the left and
                      or: 1/(C(9,3)+C(9,9))  |
| F7 | RESULT(7) | Right Ride Rate | N/mm | The right wheel vertical stiffness (tires in series) when both the left and
| F8 | RESULT(8) | Right Hop Rate | N/mm | The right wheel vertical stiffness (tires in parallel) when both the left and
