Lateral Force Camber
Request Number: 80000090
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Parallel Lateral Force Camber | deg/kN | The left wheel camber due to parallel lateral forces on the left and right
                  tire patches
                      or: 1000*(C(4,2)+C(4,4)*slr+C(4,8)+C(4,10)*slr)*rtod  |
| F3 | RESULT(3) | Right Parallel Lateral Force Camber | deg/kN | The right wheel camber due to parallel lateral forces on the left and right
                  tire patches
                      or: 1000*(C(10,2)+C(10,4)*slr+C(10,8)+C(10,10)*slr)*rtod  |
| F4 | RESULT(4) | Average Parallel Lateral Force Camber | deg/kN | The mean of the left and right parallel lateral force camber. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Converging Lateral Force Camber | deg/kN | The left wheel camber due to converging lateral forces on the left and right
                  tire patches
                      or: 1000*(C(4,2)+C(4,4)*slr-C(4,8)-C(4,10)*slr)*rtod  |
| F7 | RESULT(7) | Right Converging Lateral Force Camber | deg/kN | The right wheel center camber due to converging lateral forces on the left
                  and right tire patches
                        or: 1000*(C(10,2)+C(10,4)*slr-C(10,8)-C(10,10)*slr)*rtod  |
| F8 | RESULT(8) | Average converging Lateral Force Camber | deg/kN | The mean of the left and right converging lateral force camber. |
