/INISHE/THICK or /INISH3/THICK
Block Format Keyword Describes the initialization of thickness for shells element per element.
/INISHE/THICK/unit_ID or /INISH3/THICK/unit_ID | |||||||||
shell_ID | Thick |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
shell_ID | Element
identifier. (Integer) |
Thick | Shell
thickness. (Real) |
- This option can be used to initialize the Thickness for shells element per element. By default, property defined characteristics are used, those defined using this option are priority.
- This option cannot be used to initialize shells with TYPE11 and TYPE16 properties.
